FAST Intake/Fuel Rails Fuel Lines
Old 02-15-2008, 03:15 PM
1BDBOTI's Avatar
Default FAST Intake pics
I am Planning on installing a FAST intake on my 2002 ss camaro, i am also installing FAST fuel rails. How do you run your gas line from the frame of the car up to the intake, do they make a quick disconnect to a AN line? Give me all the tips possible thanx
Old 02-17-2008, 05:21 PM
thebart455's Avatar
well hmmm thats a tough one lol. you need to buy you some ford fuel lines and when u get them on there do be surprized if they explode. lol well friend thought that i would reply to your thread lol give you a hard time
Old 02-17-2008, 07:09 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Are you wanting to run all new lines? In tank pump and inline?
Old 02-17-2008, 10:30 PM
Disturbed Bird's Avatar
yes they do make a quick disconnect for it get the NastyPerformance fitting kit
http://www.nastyperformance.com/FuelSystem.html scroll down its 139 and comes with ss lines and all the fittings you will need
Old 02-18-2008, 08:30 PM
1BDBOTI's Avatar
i am wanting to run new lines from the stock steel lines that run to the tankup tp the fuel rails
Old 02-19-2008, 05:46 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Your title was deceiving. That is probably why the responses are limited.
Old 02-20-2008, 09:36 AM
1BDBOTI's Avatar
Default FAST Intake/Fuel Rails Fuel Lines
I have bought a FAST 90 intake with 90mm TB, FAST fuel rails and fuel line kit for the fuel rails at LS1 Speed. What is the best and easiest way to run the fuel lines to the fuel rails? I am using the sock lines fom the gas tank. Is it beat to run the AN lines just like the factory ones??? Do you run a return line. I need as much info as possible. I am a ol carb motor guy and am new on this fuel injected stuff...... I also bought FAST 36lb injectors to go along with it all. I am just havin a hard time with the fuel lines. Any tips or even pics will help out greatly. thanx
Old 02-20-2008, 10:09 PM
TLewis4095's Avatar
We make a supply line that has the quik disconnect OEM fitting to plug into your stock hard line at the firewall & a -6 AN fitting on the other....
Old 02-20-2008, 10:15 PM
TLewis4095's Avatar
Old 02-21-2008, 06:23 AM
1BDBOTI's Avatar
awsome man thanx alot i was started to get worried i wasnt goin to find any pics.... now have you installed a FAST intake yet
Old 02-21-2008, 06:25 AM
1BDBOTI's Avatar
have you installed a FAST intake on a camaro yet......
Old 02-21-2008, 07:09 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
merged the 2 like threads.
