ASC new water pump from Advance Auto Parts..Good pump..Saves $
Well, I put the new pump on today. Install was a breeze. Everything looked to be of the same if not better quality as the stock one. It comes with everything you need except the thermostat housing/thermostat; you have to re-use the stock one. It does have the thermostat o-ring though and the main gaskets, but I used GM gaskets because they looked of better quality.
I'll let you guys know how it does after a few miles. I already drove it about 50 miles and took it up to 6500RPM with no leaks an no problems.
So far, so good! After taxes, I believe it was $160.
