Throttle BodyQuestion
Old 02-24-2008, 11:37 AM
sonofmooner's Avatar
Default Throttle BodyQuestion
I was looking at picking up a Used Ported Throttle Body from a 99. I thought I had read some where there was differentness from some years to others?? Any One know if a 99 will work fine on a 98? Thanks
Old 02-24-2008, 07:01 PM
The Hammer28's Avatar
98, 99, & 2000 should all be the same. The 01's & 02's have a bigger cam spring and you can't use the on your car. You can tell that a throttle body is off of an 01 or 02 because the spring is blue.
Old 02-24-2008, 07:50 PM
89Formulaws6's Avatar
i've used a newer t/b on my 98 and had no trouble the throttle just opens slower with the bigger cam spring
Old 02-24-2008, 10:17 PM
Ah, Ok thanks
