should i Cat or not
Old 02-27-2008, 12:45 PM
Omec's Avatar
Default should i Cat or not
I just returned my QTP's i got recently (too big of gap in the primary-merge). I dont have time to install headers, have them leak, and have to remove/ install another set. Screw that. Im getting kooks and a magnaflow cat back. its a week end car that my girlfriend and i cruise around in so i dont want anything that will give us a head ache. wasnt sure if i should get the ORY or catted. dont get me wrong i want it to sound nice but no droning effect in the car while cruising.
thanks,
corey
Old 02-27-2008, 05:40 PM
00_transam_vert's Avatar
+1 Im about to do headers as well and am too not sure about Cats.
Old 02-27-2008, 10:12 PM
snake charmer's Avatar
just depends on your preference . if you are looking for power ory . if you want a quiet , clean sounding ride go with the cat . i dont think you will loose much power . with that said , considering your setup the cat sounds good. good luck with it man .
Old 02-28-2008, 12:03 AM
subobo0411's Avatar
If you don't want crazy loud, I would probably do cats
Old 02-28-2008, 06:52 AM
ok, if i do remove my cats do i run the risk of throwing any codes?
Old 02-28-2008, 08:52 AM
WS6_00's Avatar
yes, get them tuned out. and not being an a** at all here so don't take it like that, but if u do a few searches u can find a bunch of threads about cats vs ORY
Old 02-28-2008, 10:48 AM
Dskeet6's Avatar
i just ordered XS Lts...... i will be getting cats ASAP and putting them on before inspection
Old 02-28-2008, 10:54 AM
Kleeborp the Moderator™
MeentSS02's Avatar
It depends on how much you can stand the smell of a non-catted car. Por ejemplo, I can leave my truck running (it is bone stock) in the garage and I don't smell a thing. I start my Camaro (no cats), and I immediately smell the strong aroma of gas, and it is a very powerful smell. Pull out of the garage, and it is fine...confined areas with my car kinda stink. The tune is spot on, and I monitor it with a permanently installed wideband O2 sensor...the gas smell is there no matter what, and you have to get used to it. Sometimes I wish I had cats, but in the end, I'd always wonder if they were clogged.
I'll end up getting a new center section fabbed up for my exhaust with cats for inspection purposes should the need arise...but my poison is a non-catted car.
Old 02-28-2008, 11:03 AM
JScamaro's Avatar
Some cat backs are very raspy without cats. That is one thing to consider if you're getting an ory.
Gmmg and LM1 are a few examples that can get raspy without cats.
