How to remove t/c system off car?
Supposedly the only thing you have to do is buy the non tcs throttle cable and connect it from your pedal to the throttle body. I've wanted to do this for a while but have never received a definate answer.
yeah what they said!!
also when you do it, take out the tcs/cc box its next to the air pump, its about 8"x5" box.
follow the one cable from the cc box (next to the battery) to the tcs/cc box like i said above. there 4s bolts holding it in if i remember correctly and weighs about 5lbs
hope that helps
brandon
hope that helps
brandon
The 98-99 throttle cable (without TCS) is p/n 12565559
The 98-99 cruise control cable (without TCS) is p/n 12554668
The 00-02 throttle cable (without TCS) is p/n 12563627
The 00-02 cruise control cable (without TCS) is p/n 12565560
From GMpartsdirect
From GMpartsdirect
