Contemplating exhaust setup muffler on header
Okay, I posted a while back about this and I mocked it up and wanted to get some opinions. I was thinking about putting some bullets straight off the headers and running it that way. What do you guy's think powerwise and the way it will sound. Will I lose power? I thought there was a magazine article a while back that said that this setup made the most power. I am going to be running an MS4 and will be running a 4k stall. So all I am really concerned about is top end power. Well here's the pics.
IMO If you put turndowns on there that extend farther out it and aim them slightly down and out it will be no worse than regular dumped at the axle True duals with the same mufflers. I used to have dumped TDs and they resonated inside the car like crazy. Same mufflers clamped on the headers were louder like each exhaust pulse you can hear clearly but it doesn't resonate as bad. Everyone says there will be a loss in low end but bahh... that is what a stall is for.
Plus this is the one that I was going to go with. http://store.summitracing.com/partde...5&autoview=sku
Overall length of this thing is 20". That should give me the needed length of pipe after the O2's and the end of the header to allow everything to run correctly right? I thought you only needed like 15 or so inches of pipe after each header to give the needed back pressure?
