Issue w/ plugs after cam swap..
Okay.. so we just did a cam swap on my WS6.. It took a bit to get it running on the first start up but thats normal. I was driving it home and it felt like it had a pretty good miss in the low rpms and smoothed out around 3500 or so. I figured i had a loose plug wire so i got home and the next day i checked everything and put some dielectric grease on the connections hoping that would help.. Well it didnt. On the second test drive i jumped on it and it seemed to run better (no miss) for a while, but when i let it idle for a while it would miss again. This is all before the tune... So i guess im asking are the plugs done for? Will they need to be replaced since they have been fouled once? If the car smoothes out it would make me think the plugs are okay???? Also what would be a good plug to replace it w/, if needed. and its a n/a 346 cam only. TIA
Humm... it doesnt make sense tho. I didnt touch them in the cam swap.. All i did was disconnect the plug wires. If a plug was cracked i would think i would lose more power in the higher rpms, correct?
Im guessing i just need a tune.. ill swap plugs and trailer it to the tuner and hope all is okay.
how big is the cam? my car absolutely ran like **** after i swapped in a hotcam... could just be the tuning, like you said. i would change the plugs/wires anyway just to be sure...
LS1TECH Sponsor
change the plugs, then tune, dont get on it to much either as the SD tune will not adjust AT ALL for the cam . it needs to be tuned with that big of cam no question. if possible bring it to the tuner and swap the plugs after you get there. usally doesnt take to long
