ASP Pulley and belt sliding off
Installed the ASP pulley and now the belt is slipping off after long periods of driving. Is the pulley not on far enough or what? If so what do i torque it back down to? I thought it was on as far as it would go but maybe it will move a little. Also what is the size of the belt to use just with the crank pulley? (inches)
Thanks
D
Thanks
D
Re: ASP Pulley and belt sliding off
If it is sliding off the tensioner pulley (the pulley closest to the oil fill cap), you might want to try the "larry pulley". It is a pulley made by ASP that has a higher lip then the stock idler pulley.
I do not have an ASP crank pulley, but after doing my cam and raising the rev limiter, my belt jumped off a few times. The new tensioner pulley fixed it.
Good luck.
Tommy
Good luck.
Tommy
