fuel rail brackets-need pics asap
doing my Ls6 intake and had to wait over night to get a new oil pressure sending unit. i forgot where each of the brackets go when reattaching the 4 bolts for the fuel rails. need pics asap i want to get this stuff done today. need some pics to figure out where to put things back on.
There is not much to it... once you line up the injectors and place it on the Intake. there are only for brackets or L shaped tabs to where the four bolts are required to secure the Fuel Rail...
This is the best I can do.. The extra X shaped frame to support my CAI Cowl Induction Air Box.. You can see at the base of the X frame is where the four bolts go.. Hope that is what you are asking for.
Also. if you notice.. that my Fuel Rail is swapped 180 around, so that the Fuel feel is on the Passenger side..
