Best Y pipe for shorties?
I picked up a set of edelbrock shorties for CHEAP.. ala 50 dollars cheap and i want to replace my POS stock y pipe. Who makes the best Y pipe for shorties?
Also, here is the link to Thunder racing where he got it from. They are a sponsor ------>
http://www.thunderracing.com/catalog...&vid=3&pcid=99
You'll probably break the cat bolts, but you won't need them anyway. The y-pipe comes with the band clamps that you need. The only bolts you need to reuse are the manifold flange bolts. Just give them a squirt of penetrating oil the night before you take it apart and let it soak in. Mine came right out with an impact wrench.
Oh, and the band clamp bolt on the stock I-pipe. Soak that sucker good with the penetrating oil too.
