fast 92 and blue max throttle body
i just installed my new fast 92 intake and a blue maxx throttle body from vengeance.. fired up.. runs great but the throttle body seems to be sticking right when i hit the gas.. ive gotta tap the gas pedal to get it to kick down and get unstuck.. is it something ive gotta adjust on the throttle body.. or is the throttle body just messed up.. thanx in advance..
that is the spring rate, i believe all are like that to start because my new NW feels the same way. it is probably due to the new pressure that forces the blade to stay closed, like air hitting a wall.
1 Post
Good luck on picking up some ponies from the intake swap. You did have the LS6 intake correct ?? I bet you pick up a solid 20 rwhp 20 rwtq. If you don't get that much then at least you had someone pulling for you to get big gains. Again good luck.
Mine originally felt like it was sticking, but after about 75 miles of driving or so, it feels fine now. My pedal doesn't feel stiff though, unlike the FAST 92 tb. That thing was so hard to push down. I was a little dissappointed with my gains: 15 rwhp, 7 rwtq, but that's with the stock heads. Probably would have picked up another 10 or more with a nice set of heads.
