LQ4 build up?
LQ4 build up?
I am thinking about getting a complete LQ4 at a junkyard for $600. I believe its a '00, was running motor, and it looks in good shape.
Is this a good platform to mod? I want to get the engine on a stand and build it up. It will be a long term project for a 98-02 fbody. And hopefully I want it to pass emissions.
I was thinking about LS6 intake, LS6 cam, P&P heads, 85 mm TB, 85 mm MAF, 42# injectors, hone the block, forged 4.000 crank, connecting rods, forged aluminum full dish pistons for a 9.0:1 compression ratio. And eventually...boost!
the iron block is good to use for boost. Does it have a 6.0L stamped in the side? or 5.3L.
I have a 6.0 that I am getting some more info then buying some parts for a killer 408 set up.
Give them 400 cash and see if they take it. If it has 317 heads then it would be worth 600
Casting number on the block: 12551364. I initially thought it was an LM7, but then I read the casting number. I haven't got a chance to read the head casting number yet.
I am looking into a 408 stroker kit. Summit has a few, Eagle kit is about $2600 for an all forged kit. Lunati kit is ~$4000.
I may just stick with the stock bottom end and only boost about 8-10 psi. I think I will be satisfied with that.
I picked up the motor today...I verified that its a complete 6.0 liter LQ4 with aluminum 317 heads...all for $500+taxes. I bought an engine stand, waiting on a buddy to borrow a cherry picker to get it off the truck. I'm excited to start the project.
If your gonna be stroking out the motor, I'd run a larger cam than the LS6 cam. Raise the compression ratio while it's N/A so mill the LS6 heads down. Once you do go F/I then get 72cc chambered heads.
