XS Headers and rasp from the ypipe?
Old 03-26-2008, 07:50 PM
NBM-LS1's Avatar
Default XS Headers and rasp from the ypipe?
So I just put my headers on(XS) and they are awsome! Went in so smooth and I didnt have to remove any heat shields like my paceshitters. I didnt even have to cut the casting tab!
So my setup is XS headers-> XS ORY-> Magnaflow.
I seem to be getting a good ammount of rasp and a guy told me it was the ory. Is this true?
Old 03-26-2008, 08:35 PM
NBM-LS1's Avatar
anybody?
Old 03-26-2008, 08:53 PM
sixvi6-camaro's Avatar
Yes.. ORY or any Y pipe really will give rasp. Cats cut the rasp down.
Old 03-26-2008, 08:54 PM
NBM-LS1's Avatar
I dont want cats. Any other things I can do?
Old 03-26-2008, 08:57 PM
Pontiacerator
RevGTO's Avatar
The prevailing theory on here is that the Y-pipe causes the rasp. I had it on my car, and sure, it was raspy. Then I replaced it with a custom Y with Flowmaster merge and it was still raspy, but a little better. It took a combination of cats, powerpack in the I-pipe and Hooker resonator tips to kill all the rasp.
Old 03-26-2008, 09:02 PM
True duals is the only option to have no rasp or just get as quiet a cat back as you can stand.
95 Z28's Avatar
I've read that replacing the merge in the Y pipe with a real merge like the flowmaster one or maybe the Magnaflow one can cut down on the rasp from a few people on here. Not sure if that's truth or just internet myth.
EDIT: RevGTO got to it before I did.
Old 03-26-2008, 09:11 PM
Pontiacerator
RevGTO's Avatar
Originally Posted by 95 Z28
I've read that replacing the merge in the Y pipe with a real merge like the flowmaster one or maybe the Magnaflow one can cut down on the rasp from a few people on here. Not sure if that's truth or just internet myth. EDIT: RevGTO got to it before I did.
Just to be clear: the difference is not very significant. Rasp was still way beyond acceptable for me.
Old 03-26-2008, 09:31 PM
marovetsm's Avatar
I would try a dual dual muffler, that should cut down on the rasp. Or put in a bullet muffler before the axel.
Old 03-26-2008, 10:30 PM
68birdls1's Avatar
I had a thread about this not to long ago, I put a bullet muffler in mine and it helped alot. Right at the end of the y-pipe.
Old 03-26-2008, 10:36 PM
NBM-LS1's Avatar
Well the y merges pretty smoothly. I guess I will try a bullet muffler. Any ideas on which one?
Old 03-27-2008, 06:11 AM
theinstag8r's Avatar
i would try a dynomax, should help your problem
Old 03-27-2008, 09:22 AM
68birdls1's Avatar
I used a 3.5" dynomax muffler, just becuase when I bought it I thought it was a 3". But a 3" would be perfect for it.
Old 03-27-2008, 11:15 AM
tylerdj's Avatar
It's actually the Y-merge that creates the rasp. The easiest fix for this is probably to put a bullet style muffler (spiral flow, sweet thunder, bullet, etc.) in the I-pipe. This tends to quieten it down some and eliminate most of the rasp.
Old 03-29-2008, 10:28 AM
NBM-LS1's Avatar
Well i decided on two different ones. The Dynomax bullet, not stainless but less than half the price. Or the XR-1.
Can I get that bullet welded to my stainless exhaust. Sorr if thats a stupid question I donr know much about welding. I figured since it was two different metals.
Old 03-29-2008, 11:14 AM
mikenews's Avatar
Just do the high flow cats and call it a day!!!
Old 03-29-2008, 12:23 PM
NBM-LS1's Avatar
Im bitching about price. Im not going to pay some odd $90 a piece for a cat and then have them welded in for more money. Besides my car is lowered and doesnt have that much room under it for cats. I dont need them on top of that as well. I am asked if I should go with the Dynomax bullet or spend them money and get the XR-1 because its stainless and thats what the rest of my exhaust is.
There is also the possibility of the stainless spiral flow from Moroso for the same price as the DM bullet.
Old 04-03-2008, 12:25 PM
95GreenZ28's Avatar
My car has a good amount of rasp also. I even have 2 spiral flows right after the y pipe with a dump. Sounds good with the cutout open though.
Old 04-03-2008, 12:52 PM
02silvaZ's Avatar
if you dont get cats you aren't gonna get rid of the rasp, plain and freakin simple, a bullet muff gets rid of a little but you'll still have it, if you want no cats then freakin deal with the rasp, damn bro!
Old 04-03-2008, 01:17 PM
tylerdj's Avatar
Cats won't automatically elminate all rasp. Y-pipes tend to have more rasp because most have a poorly made Y-merge.
