5.3 verses 5.7 Crank ((Which is stronger?))
Old 03-27-2008, 11:43 PM
barnat's Avatar
Default 5.3 verses 5.7 Crank ((Which is stronger?))
Hey guys my buddy told me the 5.3 truck crank at 3.622 is stronger then the stock LS1 crank which is also 3.622 Is this true? if not what are the diffrences if any between the two ??? Any info WILL BE GREATLY APPRECIATED !!!Thanks BARNAT!!
Old 03-28-2008, 12:19 AM
RoDan's Avatar
I doubt it, but here is a good source: http://www.babcox.com/editorial/ar/eb040538.htm
Scroll down and look at the Crankshaft section. It doesn't say much about them, but they seem to be the same just different part numbers and bob weights.
Old 03-28-2008, 07:44 PM
barnat's Avatar
Default thanks
Thats what i was looking for and even learned a little more too!! Like about 98 blocks only being bored to .004 and ls1s to .010. Some food for the brain LOL!!Thanks guy!BARNAT
Old 09-25-2008, 03:54 PM
Grn4fbody's Avatar
So from what I read as long as you re-balance the 5.3 crank you can use it in a 5.7?
Old 09-25-2008, 04:59 PM
Grimes's Avatar
I have never heard of any difference in strength. The stock LS1 crank will take pretty much anything you can throw at it.
