pcv catch can or breather
Old 04-03-2008, 01:28 PM
Apollo0526's Avatar
Default pcv catch can or breather
Is it better to vent it through a breather or retain some vacuum on the crankcase?
Old 04-03-2008, 05:21 PM
Apollo0526's Avatar
no inputs
Old 04-03-2008, 06:08 PM
Viper's Avatar
Catch can for daily driver. Vent for full race car. My $.02.
Old 04-03-2008, 06:10 PM
Deeavi's Avatar
What Viper said!
Old 04-03-2008, 06:13 PM
Evans752's Avatar
Catch can
Old 04-03-2008, 08:50 PM
Apollo0526's Avatar
thanks
Old 04-04-2008, 02:55 AM
Y2K SS's Avatar
I had that dilema awhile back and decided to do the LS6 PCV mod. http://www.ls1howto.com/index.php?article=18 Took a little while but glad I did it.
Old 04-04-2008, 09:50 AM
TLewis4095's Avatar
For a street application you deffinatley want to pull vacum at idle & low rpm's to remove the harmful gasses & vapors & a catch can is insurance against oil mist entering the intake. As Viper stated, on a race application breather will work as long as the oil is changed every few races unless Alky is the fuel, then you will need a belt driven vac pump to remove the moisture & unburnt fuel from the crankcase.
Old 04-04-2008, 11:49 AM
bczee's Avatar
You do need some neg pressure in the engine to operate with out blowing seals, The PCV system will assist along with a Catch Can..
Breathers do work.. but can get messy... but does nothng to evaculate the gasses in the inside of the engine.
This is a debate that will go on forever..Do some research with the search...
IMO, if it is a street Car use a PCV system & Catch Can.
Old 04-04-2008, 01:18 PM
TLewis4095's Avatar
Well stated.
Old 04-04-2008, 03:40 PM
Apollo0526's Avatar
got a few quick questions,
-the orginal hose that came off the car, next to the intake, the ground strap. Should i keep that part, or can i just use some fuel hose?
-the hose from the front of the passenger valve cover to the TB, What exactly is that for?
Old 04-05-2008, 08:45 AM
bczee's Avatar
1- It may look like a ground strap.. but it is only there to hold the PCV in place. Yes, you can use any other type of hope that is correctly rated for use as for a PCV system.
2- Fresh air intake for the PCV system.
Old 04-05-2008, 08:47 AM
Joshiedoom's Avatar
PCV Catch Can and Oil Cap Breather for the win!
