Important Meziere Street Pump Questions !
Like most on this board I'm anticipating the release (when I can actually get my hands on one) of the Meziere street pump. However I have a couple of important questions, hopefully Thunder or someone who has access to the pump will jump in and answer them:
1. What is actually used for the Thermostat ?
2. Any additional items needed to make this work or does the unit include everything needed for an start to finish install ?
3. Has the wiring been designed for simple plug and play or does it require an electrical engineer (J/K) ?
4. Is the pulley closer to the radiator than stock ? This is 'really' important for those of us who are running thicker than stock radiators. The concern would be between the radiator, upper radiator hose and the Meziere pulley.
Thanks in advance to those who can contribute...
Re: Important Meziere Street Pump Questions !
[B]1. What is actually used for the Thermostat ?[B/]
Hope this helps....
