Are the Pacesetter Ypipes crimped like stock ypipe?? Pics-->
I really cant tell but I was wondering if anyone knew for sure.
http://community.webshots.com/photo/...73903976maNVsh
http://community.webshots.com/photo/...73903974qgidPC
I was going to go with QTPs but ill save $550 and use the money for a nice cam. I plan on adding the flowmaster y-collector to the Pacesetter y pipe as long as they dont crimp them. Otherwise Ill get a custom Y.
Re: Are the Pacesetter Ypipes crimped like stock ypipe?? Pics-->
Okay, then if anything, I think this is why the Pacesetters would put less HP than other systems, because ofthe low quality Ypipe. With a good mandrel bent non-crimped ypipe and a flowmaster y-collector, I think the pacesetters should make within 15% of the HP of the top dollar brands. Like an extra 25-26RWHP instead of 30-31. 5 hp is worth saving $500 to me!
LS1Tech Premium Sponsor
I just got off the phone with Pacesetter and they said they use mandrel bent pipe so there should be no crimp in the y-pipe.
Brian
Brian
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
Texas Speed & Performance
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
The Pacesetters are a Hooker knock off. Their Y-pipe is also, but instead of putting in three indentations, they just made a continuous flattened area. Most likely because the Hooker would still bang the floorboards a little, and its most likely cheaper.
Ive Got a question?Can you get another y pipe from another vendor to put it on the pacesetters that is not bent.
There is nothing wrong with the y-pipe design. Like was mentioned earlier the hooker y-pipe has three indentions, where as the pacesetter has one long flat area. Now I'm no "flow-guru" but it seems to me that hooker y would create turbulance with the multiple indentions. I can tell you this much the pacesetter has NO CLEARANCE ISSUES WHAT SOEVER. These are a quality designed header. Save your money for the cam.
