2000 A.I.R. removal
2000 A.I.R. removal
I finally pulled off my air system and I did find some good articles that showed how to do it for the 98-99's. However the 2000 has a valve up by the block where the others just have a T adapter. It is attached by a bracket and there are some wires to it. Anyone have some pictures or instructions how to get that thing off? I can't seem to get it out....
Was this the thread you used? If not maybe there is something in here that can help.
https://ls1tech.com/forums/generation-iii-external-engine/673299-air-removal-pics.html
There is a little vacuum line that should be left over after you take everything out. Just thread a screw into it to block it off. I believe there is a thread somewhere with a picture of it. Also, that bolt your talking about, that holds that bracket on, is a pain. It was behind the head and there was no room to get at it. I think that is the one you might be referring to.
