driver side exhaust manifold
Old 05-05-2008, 03:54 PM
plaf713's Avatar
Default driver side exhaust manifold
im am in the middle of my header swap, and i am having a tough time trying to get the driver side exhaust manifold out, i can't get to the bolts above the cat to seperate the two, i know this is my problem but those bolts will not budge whatsoever. ANy tips on how to get this thing out?
Old 05-05-2008, 05:04 PM
Eric95's Avatar
i just did my headers this weekend and those bolts were hard..I just put a bar on the end of my wrench and forced them..2 of the bolts broke off but it didnt matter because the cat still came off
Old 05-05-2008, 05:53 PM
plaf713's Avatar
so you suggest to just try and knock them off? sounds better than anything ive tried so far, those bolts are damn hard to get to as well, its pissing me off and really slowing down the process
Old 05-05-2008, 06:01 PM
motoo344's Avatar
How high can you get your car? If you can get it high enough, you can remove it all as one piece.
Old 05-05-2008, 06:16 PM
plaf713's Avatar
its high enough to remove as one piece, but it just wont come through the bottom
Old 05-05-2008, 06:31 PM
motoo344's Avatar
I had to get mine almost vertical to get it out. The manifold that is...
Old 05-05-2008, 06:47 PM
plaf713's Avatar
i dont understand how you would be able to get it vertical, the cat would not allow for it to happen, atleast in my own experience
Old 05-05-2008, 06:55 PM
02silvaZ's Avatar
i just did headers a couple weeks ago and got mine out in one piece, dunno
Old 05-05-2008, 06:59 PM
plaf713's Avatar
**** i cant understand it, you guys took the manifold and the cat off as the same piece?
Old 05-05-2008, 07:01 PM
02silvaZ's Avatar
^yes sir
02silvaZ's Avatar
ya got wiggle it a little bit, and then some more
Old 05-05-2008, 11:28 PM
massls1guy's Avatar
It was a while back now... but I used my 1/2" drive 18" craftsman breaker bar on the bolts that were frozen. Made a few trips for 1/2" extensions and sockets when I muscled the old exhaust off. Of course spray penetrant helps but a lot of the studs & bolts just broke off.
Old 05-06-2008, 11:28 AM
plaf713's Avatar
Finally i got it out, it took only 3 minutes, i really wasnt even doing anything and it pretty much just fell out, lol what a pain in the ***, but im happy its out.
Old 05-06-2008, 11:29 AM
xBROKEx's Avatar
it will if you remove those two bolts that hold onthat elbow thing near the oil filter
