broke header bolt, what do you guys think?
i broke the head off of the header bolt, i probably overtorqued it. I got it all the way in and it looks tight, should i worry about a leak or not? TO be honest it looks like its tight to the head, just dont know what to do
Right angle drill with a left handed bit if you can get that in there. Once it grabs it should back itself right out. If not use an easy-out. You may have to go back with a heli-coil. Torque the new bolt to 18 ft-lbs.
