P&P TB: noticeable gain?
Old 05-09-2008, 01:42 PM
Gottahavels1's Avatar
Default P&P TB: noticeable gain?
I have all the boltons except a P&P TB and intake manifold. I plan to get her tuned this summer and wanted to get my TB ported and polished but can't find a cheap or easy way to do it. My dad says he's not a pro with that and we'd have to buy tools. My friends dad could do it, but wasn't interested when i offered him $50. I know that new era performance does it for $75, but i'm really strapped for cash. is it worth doing???
Old 05-09-2008, 02:54 PM
phantazn's Avatar
definitely better throttle response. as for hp gains, doubtful unless you do the bumpstop mod at the same time.
Old 05-09-2008, 02:57 PM
AlexLs1's Avatar
A definate better throttle response. You tend so see more of a gain in cammed cars.Not so much with bolton cars.
You might was well just wait if you plan on doing a cam down the road. Thats my opinion, just cause you'll see the most benefit.
If you arn't planning on putting a cam or any other internal work, its up to you. You'll see a gain, somewhat.
Old 05-09-2008, 03:10 PM
chrs1313's Avatar
definitely worth doing with my tb...i have it 3/4 shafted so there is half of the bottom shaft holding the butterfly...plus bo white ported and polished it...i can almost guarantee with my cam only it added 10rwhp...
Old 05-09-2008, 04:36 PM
Pontiacerator
RevGTO's Avatar
Bo White ported here - nice improvement in throttle response, but I didn't see anything at the track. I think the results are worth the $75. I would do it again.
Old 05-09-2008, 04:38 PM
JimsWS6's Avatar
that was my first mod and I was shocked with the gain I got. More than the lid and ssra combined. Mostly better throttle response and stated, more low-mid range grunt. If done right you'll gain
I just used a die grinder with a cutting bit I got from eastwood. Them used sanding discs I also got from eastwood, and finished the sanding by hand. Them polished her up with compound. Just don't touch where the blade closes
Old 05-09-2008, 04:52 PM
95 Z28's Avatar
I didn't notice **** personally. My butt dyno is weak though. I chalked it up as an "every little bit counts" mod.
Old 05-09-2008, 05:22 PM
connexion2005's Avatar
I definitely chalk it up as the every little bit counts mod. The kind of mod that may push you .05 in et or .5 mph. Definitely a must if you are building up towards a cam.
Old 05-09-2008, 05:36 PM
_JB_'s Avatar
Noticed a better throttle response, not sure about the rest.
Old 05-12-2008, 08:53 AM
Bad Blue WS6's Avatar
yes it is.
Old 05-12-2008, 09:26 AM
99blancoSS's Avatar
Its in the every little bit help category.
