port and polish intake?
Old 05-13-2008, 09:44 AM
a338566's Avatar
Default port and polish intake?
Is this something the individual can do or should it be sent out? If it is something you can do, are there any write ups that give good instruction? I have done a couple of searches and came up with nothing.
Thanks,
Joe
Old 05-13-2008, 10:08 AM
ss.slp.ls1's Avatar
What year is your car? If it's a 98-00' you are MUCH better off getting a LS6 intake manifold than trying to port your LS1 manifold.
Old 05-13-2008, 10:14 AM
a338566's Avatar
sorry it is a 2001 trans am
Old 05-13-2008, 10:21 AM
ss.slp.ls1's Avatar
DIY porting is a touchy subject, some have seen good results, some have made paper weights.
What are your current mods? Most likely you should concentrate on other areas of your engine before you have to touch the LS6 manifold.
Old 05-13-2008, 10:37 AM
a338566's Avatar
I have Pacesetter LT's w/ true duals no cats, new plugs and wires, predator tune, SFC's, LCA's, 4.10 gears, UMI torque arm, UMI Torque arm relocation bracket (transmission crossmember), SLP lid w/ kn filter, 160 t stat
Old 05-13-2008, 10:48 AM
ss.slp.ls1's Avatar
It looks like you have all of the supporting mods for a good cam swap. I would leave the manifold alone, It is a well designed piece. I recommend getting a TR224 or a F13 cam. You'll be much happier spending your money that way.
EDIT: You could also get a aftermarket or p&p TB.
Old 05-13-2008, 10:55 AM
a338566's Avatar
i am doing at least a cam swap this fall or late summer, i would like to do the heads at the same time, but that is pending the funds being there yet.
Old 05-13-2008, 11:01 AM
ss.slp.ls1's Avatar
I hear you. The F13 will make a good cam-only swap if funds are short, you will need to get dual springs with that. Get a TB, get a mail order tune, and you will be putting down some nice numbers.
Old 05-13-2008, 11:05 AM
a338566's Avatar
Where do you get a F13?
Old 05-13-2008, 11:06 AM
ss.slp.ls1's Avatar
Futral Motorsports
Old 05-13-2008, 04:29 PM
King Nothing's Avatar
keep a look out in the classifieds for heads . . . i got a great deal on some 241's from my buddy and i'm gonna have them p&p then installed with a tr230 cam
GOOD LUCK!
Old 05-14-2008, 02:59 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I dont know if you would want a polished intake man.
Old 05-14-2008, 07:14 AM
a338566's Avatar
I typed intake, meant Throttle body, sorry
