LS1/LS2 intake swap - any issues?
Old 05-15-2008, 10:12 PM
SOS2000's Avatar
Default LS1/LS2 intake swap - any issues?
I am looking to swap my LS1 intake for an LS2. Has anyone ever doen this and can you tell me what I am going to need to do? I am looking to run an LS2 throttle body too.
Old 05-15-2008, 10:20 PM
Grimes's Avatar
The LS6 intake is actually a better performer. I would do that instead.
You'll need to get LS6 coolant lines. However, if you want to use your LS1 lines, clearance the underside of the LS6 intake by breaking/grinding off the small ribs that are in the way.
Old 05-16-2008, 05:12 AM
SS101's Avatar
running an ls1 will require a 90mm TB and a throttle cable bracket (i recommend holley's 90mm TB because 1. it's a really nice unit and 2. it comes with a cable bracket). you'll need fuel rail/injector adapters (available from Katech for about $25) and a MAP sensor harness extension (also available from Katech for about $14). ls6 coolant lines too.
Old 05-16-2008, 07:44 AM
SOS2000's Avatar
Thumbs up
Sounds like you have used this setup before. If you have, how did/do you like it and what is the comparison to using an LS6?
Also is what you have listed here all I need to put this thing on my car and how difficult is it to do it?
Thanks for your help
Old 05-16-2008, 08:47 AM
ss.slp.ls1's Avatar
It's pretty common knowledge that the LS6 intake outperforms the LS2. I would get the LS6, hands down, you can get them used for $350.
