How to test for exhaust leak?
I may have an exhaust leak because my lc-1 reads way lean. I hear a slight tick once in a while on the driver's side but its not consistent. Car has longtubes, pacesetter y. I tightened all the exhaust clamps and everything lookgs good below.
when i had one i just idled the car, went under and followed the noise until i found the air with my hand-is it under the car or a leak under the hood? maybe your hearing the motor knocking? i could be wrong.
just jack the car up. and rub soapy water over where the pipes meet. Make sure there is alot of suds. And then start you car. If there is a leak there should be bubbles. Make sure you do this on a cold start. Other wise the heat will fry the bubbles before you can check all the places. Good luck
