Bought a dyna battery like the one on thunders website HELP!
Old 08-08-2003, 09:50 PM
needmoremoney's Avatar
Default Bought a dyna battery like the one on thunders website HELP!
Very nice battery and only weighs like 11 pounds. Here is my problem; I cant mount this small thing, and I cant have it flop around in the engine bay. For those of you who have these small batteries, how did you moount it? Thunder sells a direct fit battery tray for it, but its 125 dollars. Any ideas people? Also need it to look nice too.
Old 08-08-2003, 10:37 PM
ratio411's Avatar
Default Re: Bought a dyna battery like the one on thunders website HELP!
As small as that is, along with the fact it is dry cell... I would mount it out back in a nook or cranny.
Pull up one of the rear side speaker panels and find a spot to hide it. It looks like it might even fit behind the spare. If you still have one...
Dave
Old 08-09-2003, 01:17 AM
DONAIMIAN's Avatar
either that or make your own bracket for it.
Old 08-09-2003, 02:12 AM
4thGENRETARD's Avatar
Cheap alternative. Use very long plastic strap with lock end, (find them at home depot). Run the thing over/under actual tray. Not bad looking either just a thin plastic strap showing. Worked fo me Cost $2. If u can't locate one long enough, run 2 or 3 shorter ones in series.
Old 08-09-2003, 07:21 AM
redz_02's Avatar
you could always run a strap adn then get a battery cover.
