Best place for wideband with LTs true duals?
Old 05-21-2008, 01:07 AM
mvvette97's Avatar
Default Best place for wideband with LTs true duals?
Where do you guys usually put the O2 at? I was thinking it would be good to put it in the X pipe but then I would just have more wire to mess with. Any pointers would be great before I install this thing. thanks
Old 05-22-2008, 08:04 PM
99SSragtop's Avatar
my wb bungs are on the opposite side of the primary o2's
Old 05-22-2008, 08:18 PM
BriancWS6's Avatar
I put the bung for my sensor on bank 1 just a little piece back after the header. Since the number 7 cylinder is the one that will go lean first, it would make bank 1 the leanest in theory, plus, it was also less hassle
Old 05-23-2008, 08:53 AM
jmm98LS1's Avatar
^^^^That's where I've got mine too, and for the same reason.
Old 05-25-2008, 11:12 PM
GGTTOO's Avatar
I would say in the collector on the drivers side.
Quick Reply: Best place for wideband with LTs true duals?
