Damn Valley Cover Bolts....
Old 05-24-2008, 01:42 PM
408Maro's Avatar
Default Damn Valley Cover Bolts....
ok so i got my FAST intake and being the genius that i am i put on the intake and then start searching on the intake and read i need to swap the valley cover bolts. so i take it off and noticed i did what nobody wants to do and thats put 10 nice dents in the lower intake. i dont see any carcks but dents from the bolt heads. is this ok?? or do i need to replace the lower intake?? thanks guys also this was only running for 30mins max so why is there alot of oil around the intake where the vaccum lines atach? and alot of oil on the gaskets? thanks and please help me
Old 05-24-2008, 01:45 PM
408Maro's Avatar
by the way i bought this intake used so all i need is the 10 lower and top bolts right? it already has the 6 short allen bolts on it. thanks
Old 05-24-2008, 02:03 PM
theblur98ss's Avatar
As long as it isn't cracked you should be ok. The bolts you need are button head allen bolts.
Old 05-24-2008, 02:08 PM
408Maro's Avatar
and those button style ones are the ones i need to use for the bottom right? so i can reuse the stock top 10?? thanks
Old 05-24-2008, 02:12 PM
Restricted User
socmguy's Avatar
Yes, the hardware kit isn't expensive or you can just buy some locally. WS6store has 'em.
Old 05-24-2008, 08:45 PM
Yes just the 10 for the valley cover. I'm not sure if the top 10 are the same as stock or not. Should be fairly easy to tell if they'll work though.
