what to do to swap ls1 for ls2
Old 05-26-2008, 05:52 PM
myfirstSS's Avatar
Default what to do to swap ls1 for ls2
want to put just the ls2 block and use my my heads and intake. do i just have to change the reluctor wheel on the crank or is there more than that?
Old 05-26-2008, 10:34 PM
twitchtwice's Avatar
why do you want to do this?
Old 05-26-2008, 10:59 PM
ss.slp.ls1's Avatar
+1. Why? Just to go from a 5.7 to 6.0 and see marginal gains?
Old 05-26-2008, 11:07 PM
theblur98ss's Avatar
You will need new front and valley cover, relocate knock sensors to side of block and get the cam sensor wiring adapter.
Old 05-27-2008, 12:23 PM
if you spend the same money of mods on an ls1 as buying a new block you will see more performance gains.
Old 05-27-2008, 02:17 PM
ss.slp.ls1's Avatar
^^^+1.
Old 05-28-2008, 06:38 PM
myfirstSS's Avatar
cause i have a cusomstion of oil problem and probaly gonna get motor fixed or replace. if i get it replace was thinking of just paying the diference and go with the 6.0 block instead if it wasnt to much trouble
