meizere wp/ drill stat? reuse gaskets?
Old 08-16-2003, 10:50 AM
highgmc's Avatar
Default meizere wp/ drill stat? reuse gaskets?
I will be installing the street meizere wp this weekend and wondered if I should drill the thermostat like some guys are?
if so what size and where exactly should I drill the holes.
can I reuse my waterpump gaskets?
Old 08-16-2003, 08:19 PM
highgmc's Avatar
Default Re: meizere wp/ drill stat? reuse gaskets?
just picked it up from summit, the holes need to be 3/16" I see.
can I reuse my gaskets? they only have about 250 miles on them.
Old 08-16-2003, 08:27 PM
Scalpel's Avatar
I thought this one was only available through Thunder Racing, the Street Pump.
Old 08-17-2003, 12:32 AM
Pathological Modifier
Ryan K's Avatar
Levi, it available in all places now, Thunder had a preproduction shipment due to a sweet deal. They did all the initial fitmaent and dyno testing!
And you can reuse the gaskets "if" they used the steel ones with the rubber. 98-99 cars origianly used a paper type.
Ryan
Old 08-17-2003, 08:45 PM
JaSSon's Avatar
How much was it from Summit?
Old 08-17-2003, 08:52 PM
Scalpel's Avatar
Sweet, thanks for the info on the availability. I'd like to know how much it is from Summitracing, too.
Old 08-18-2003, 05:02 PM
highgmc's Avatar
$499 but I recommend buying from thunder, they give you a stat with it I think.
