heard stainless headers like to crack.... is this true?
Old 08-16-2003, 10:54 AM
BigPlanTransAm's Avatar
Default heard stainless headers like to crack.... is this true?
i am strongly considering a set of QTP headers but now that i've heard this about stainless headers it may not be such a good idea. so is this true or not?
Old 08-16-2003, 01:05 PM
2002 Trans Am's Avatar
Default Re: heard stainless headers like to crack.... is this true?
I highly doubt that.
Borla and Corsa use 304SS and they offer lifetime gaurantees. Also 304SS is supposed to be aircraft quality of something like that. So if its good enough to go on an F-16, its good enough to go on my Trans Am
Old 08-16-2003, 09:11 PM
Moderator
jimmyblue's Avatar
It wouldn't be an issue with the stainless tube, it
would be with welding process workmanship (pre- and
post-heat) and quality control. You can get brittle
welds in stainless more readily than mild steel.
And, with cost of materials and more difficult
bending, manufacturers might be tempted to go with
thinner walled tube which only makes the welding more
critical.
Until the new brands of stainless headers have seen
a lifetime of heat cycles, you just won't know. An
aerospace part would have to be run through a qual
regimen. Good materials alone do not suffice. You
can turn good material into junk very easily.
It'd be great if the vendors had the kind of test
data and QC that certainty would require. But this
is where hammers get to be $500. You don't plan on
paying aircraft prices, I reckon.
Old 08-16-2003, 10:44 PM
98 LPE SS's Avatar
I had a set of SS LPE headers for several years and never had any cracking problems. There are a lot of SS mufflers and exhaust systems and I have never heard any report of cracking in those either.
Old 08-17-2003, 10:20 AM
MIGHTYMOUSE's Avatar
stainless is the best you can buy.. problem comes when a manufacturer doesnt build them differently from a mild steel header.. stainless swells 5 times more than mild steel, and that has to be taken into consideration..or else..
Old 08-17-2003, 12:54 PM
MyLS1Hauls's Avatar
Big difference between the amount of heat a muffler at the back of the car sees and what temps headers see.
Old 08-18-2003, 10:22 AM
LS1Tech Sponsor
Slowhawk's Avatar
On turbo cars the stainless headers are prone to crack.My GN lets me know that.
Also on a car Stainless headers are prone to crack if you wrap them with Header wrap.(Which not to many people do nowadays)
