easiest way to gut factory cats
Old 08-17-2003, 04:29 PM
ta12sec's Avatar
Default easiest way to gut factory cats
I decided to gut my factory cats, i took them off and had no problem gutting the drivers side catwith a pry bar. Then I picked up the ypipe/pass cat and said htf am I gonna do this. Well after a l,il bit of thought I figured it out 10 welding rods with a hose clamp on each end about 2 inchs from the tip. Then I stuck it in an air drill and gutted the cats in about 5 minutes using it just like a toilet snake. I cant imagine how else you could ever get all that out?
Old 08-17-2003, 07:08 PM
Administrator
unit213's Avatar
Default Re: easiest way to gut factory cats
Just beat the snot out of them.
Old 08-17-2003, 09:02 PM
1BadAzzWS6's Avatar
long pipe and a hammer....thats it!!!
Old 08-18-2003, 01:36 AM
soundengineer's Avatar
un-bolt em...use a pipe and a hammer.....re-bolt em....
or just buy my old ones.... send me a private message if you're interested.
Old 08-18-2003, 11:49 AM
Team ZR-1's Avatar
Cut the top of the cat open (so its hidden from view), gut and then reweld shut.
