please help with air pump
Old 08-19-2003, 01:19 PM
muscleSS00's Avatar
Default please help with air pump
I removed my air pump and all lines! Was told it would not throw code but it did! Is there anything I can do like a resistor to fix the code! thanks if any has any ideas!
Old 08-19-2003, 03:25 PM
JF WS6's Avatar
Default Re: please help with air pump
Did you pull the fuse for the airpump also?
Old 08-19-2003, 04:10 PM
Mike K.'s Avatar
If you pull the fuse dont you still get a power not plugged in air pump code or something? I know LS1 edit can take care of this code but I'm not sure of any other way.
Old 08-19-2003, 05:15 PM
JF WS6's Avatar
Yeah, it's possible...... I had a shop install my heads/cam and they went ahead and pulled the airpump assembly off as well and I noticed that they pulled the fuse for it. It was just sitting there unplugged in the fusebox that's why I asked.... If it did throw a code I'm sure they just deleted it with edit, but I'm not sure.
Sounds like it does throw a code from what I gather but for some people it has gone away eventually. I guess I'd just live with it and see what happens (maybe it will eventually dissappear) or have somebody get rid of it with edit.
Old 08-19-2003, 07:53 PM
muscleSS00's Avatar
thanks for the help, going to pull the fuse now! Any other advice?
Old 08-19-2003, 07:54 PM
muscleSS00's Avatar
thanks for the help, going to pull the fuse now! Any other advice? ttt
Old 08-19-2003, 09:49 PM
muscleSS00's Avatar
ttt
Old 08-19-2003, 10:01 PM
Ferocity02's Avatar
Probably just have to do some LS1 Edit on it so it knows it doesn't have the AIR pump anymore. And don't TTT every couple hours, we see you, don't worry
