Meziere EWP dyno numbers.....
Got Mark nailed down this evening to get some results after the pump swap...
407/389------->>>>>417/401
I basically gained back the losses from the Moser install!!!
I will post the graphs tomorrow...
Here are some pics from this evening....
http://community.webshots.com/album/85971315sZVElP
I also took a couple of clips of dyno runs...Hopefully they will be up also.
Nite...nite...
Oh yeah, it was 101 in the shop tonite....I am thinking I could be over 420 in cooler weather
Nite...nite...
Re: Meziere EWP dyno numbers.....
Almost forgot...when I was letting it cool between pulls I left the ignition on to keep the pump running and put the fans on low....on my last pull it cooled down to 130 deg!!!!!
I am trying to figure out how to do that. I talked to Dynojet and thought I had it figured out...but I can not get the "Run Viewer" to open the file I downloaded from WinPep. I must be missing something simple???? The graph shows a gain across the band!
FYI......Mark at Raging Motorsports---------->
is getting a large order in at a price that will not be available for long.......$420. I think they are going up to $570ish.
There is not much weight difference between the stocker and the Meziere.
