getting LS6 intake from 02 car, what do i need?
As the title says, i'm going to be getting an ls6 intake off of an 02 car, i have a 2000 t/a, What am i going to need to install it/ what am i going to have to tweak. If it helps i have race headers so no egr/air.
+1. reuse all gaskets etc. and grind down the ribs. or buy coolant block offs. but i got rid of the ribbs and have no issues. a lot of people break their OPS when doing the install. it may not be a bad idea to have one ahead of time just in case. and return it if you dont need it.
i wouldn't worry about the oil pressure sending unit. I've just started working on cars, this one being my first so i am no expert at all, and i didn't break the OPS. It's right behind the intake, so when your pulling it off i lifted the intake up from the back out.
Also you don't need coolant crossover lines if you grind down the ribs underneath the LS6 i shaved all of them down here a link to someone else intake after they shaved them down.
https://ls1tech.com/forums/showthrea...light=ribs+ls6
