Bad oil leak from rear of the oil pan????
Old 07-22-2008, 11:24 PM
nova2427's Avatar
Default Bad oil leak from rear of the oil pan????
Just as the title says, after the first start H/C. All of the bolts were torqued to spec, but I noticed that most of the oil was coming from the oil filter or the "stem" above the filter (I"m not actually sure of what it is). Is there supposed to be a plug, or bolt in it???
http://youtube.com/watch?v=_dbO5suLyzM
I posted the video, not because it has any relevance to the oil leak, but because It is so friki'n cool!!!
P.S. It sounded so much better than my Cobra ever did!!!!!!
Old 07-23-2008, 09:47 AM
nova2427's Avatar
daily bump!
Old 07-23-2008, 10:13 AM
ss.slp.ls1's Avatar
All you did was a H/C swap?
Try posting some pics to help us out.
Old 07-23-2008, 01:26 PM
nova2427's Avatar
I had to remove the oil pan, because I dropped a bolt in it while installing my double roller timing set up. Notice the stem above the oil filter threads. Could that be my problem, or did I accidentally leave the old oil filter seal stuck on the oil pan and just threaded my filter below it??
Old 07-23-2008, 01:28 PM
99NMB's Avatar
Are you talking about the plate looking thing above where the oil filter mounts. the thing is that is held on with two bolts? yes that is required, it needs to be on there.
Old 07-23-2008, 01:33 PM
ss.slp.ls1's Avatar
I don't think you would have all of a sudden sprung a leak from that "stem". Most likely is that when you put the oil pan back on, it wasn't sealed properly. Did you use RTV in the corners?
Old 07-23-2008, 01:45 PM
nova2427's Avatar
I used RTV for the timing cover and that is it. The leak is much worse than not sealing the oil pan up properly. I lost about a half of a quart in 3 start ups.
Old 07-23-2008, 01:52 PM
ss.slp.ls1's Avatar
You have to use RTV in the four corners (covers meet the block) of the block where the oil pan bolts up. I could see that being lost throught oil pan. But you're going to have to explore all options. If you didn't touch that plate above the oil filter adapter, than its most likely not the source of your leak, but it wouldn't be too hard to remove it and replace a gasket (if it has one) I suppose. Did you try removing the oil filter and making sure it's sealing properly? You didn't by chance break the oil sending unit did you?
Old 07-23-2008, 06:54 PM
Omec's Avatar
did you double up the oil filter gasket possibly?
Old 11-27-2008, 11:15 AM
Sweet Muscle's Avatar
Default Do you know what this part is called
I have just sprung a small oil leak, so I take it to my mechanic and he says its leaking from the part you mentioned with the 2 bolts, but he can't source it. He says that it is probably a seal behind that piece with the 2 bolts.
Any info is greatly appreciated.
Old 11-27-2008, 01:48 PM
ss.slp.ls1's Avatar
It's very easy to remove the oil filter adaptor. Drain the oil, remove the two bolts, then pull off the adaptor. Replace whatever seal is behind it, should be able to get new ones at AZ.
Old 11-28-2008, 05:54 AM
the_merv's Avatar
You don't have to drain the Oil to remove that, you just have to remove the Filter and get the Oil out of the Oil passages in that area. I've done a couple of them, all that piece is is a factory Oil Cross-over. Some Trucks and the Vettes have the Oil Cooler there.
Old 11-28-2008, 09:06 AM
ss.slp.ls1's Avatar
Camaro SS as well.
