TSP Rumbler exhaust tip suggestions
Old 07-23-2008, 10:57 AM
mrnorm_hemicide's Avatar
Default TSP Rumbler exhaust tip suggestions
Hey all,
I'm getting ready to buy one of the TSP Rumbler catback setups (not the true duals), and I was wondering if anyone who has run this setup has used different exhaust tips than what they offer. I do not like the oval tips, and I have no idea what the ractiv tips look like, so I wanted to use something else. The system is 3", so does the inlet diameter of the tips have to be 3"? Any advice anyone can give me would be greatly appreciated. Thanks.
Old 07-23-2008, 12:01 PM
BlueBird346's Avatar
You can get 2.5 inch tip inlets and a muffler shop can swell them and weld them on.
PS. This system sounds amazing in a parking garage lol.
Old 07-23-2008, 01:04 PM
Kingc8r's Avatar
LOL, if you can hear it over all of the car alarms
Old 07-23-2008, 01:15 PM
95 Z28's Avatar
Summit and Jegs both have a ridiculous amount of tips on their sites. Hours of entertainment, check it out.
Old 07-23-2008, 02:56 PM
What do you mean by "swelling" the tips? Do you mean expanding the intlets to fit the system, or crimping the system's pipes to fit the tips? Reason I ask is b/c I have a muffler shop right down the street but they are a little slow in the head, the kinda guys that rode the little bus to school, and I might need to explain this to them. Thank you to everyone for the input, and I can't wait to get this system!
Old 07-29-2008, 11:29 PM
They expanded the tailpipes on mine. I think they couldnt do the tips because they were too thin.
Old 07-29-2008, 11:51 PM
noriceinside's Avatar
i had the rumbler on my 02. i got some hooker dual/dual chromies with 2.5" ID. clamped em on just fine. this time around though i got some corsa clones for my 99. arrived yesterday. wow. just. wow.
anyway this is what i had on my 02.
Attached Thumbnails TSP Rumbler exhaust tip suggestions-new-028.jpg   TSP Rumbler exhaust tip suggestions-new-045.jpg
Old 07-30-2008, 01:43 AM
7camaro7's Avatar
Originally Posted by mrnorm_hemicide
Hey all,
I've got mine hooked up to my cme
Old 07-30-2008, 07:07 PM
LS1 Terror's Avatar
i have the TSP rumbler and had the stock Z28 tips when i wanted the stock look.luckily my friend disliked his GMMG ovals and but those bad boys on sounds awesome.not to raspy
Old 07-31-2008, 10:04 AM
Well, just bought the system and the tips. Here are the tips I went with: http://store.summitracing.com/partde...0&autoview=sku. They are 3" id, 3.5" od, 11" long Hooker chrome slant cut tips. I figured that 11" would be just the right length, not too long, not too short. I'll post up some pics when I get the exhaust all hooked up. Thanks for all the help guys!
Old 07-31-2008, 10:52 AM
primer84z's Avatar
the tail pipes are 2.5" on the rumbler system, same size as stock.
Old 07-31-2008, 01:47 PM
Are you sure about that? TSP lists it as a 3" catback.
Old 07-31-2008, 06:27 PM
primer84z's Avatar
the main pipe is 3". When it splits back to the two tail pipes they are both 2.5". I am positive, I have one.
Old 07-31-2008, 06:32 PM
Thanks for the heads-up. Why do they do that , must be so that people can use factory tips like the CME.
Old 07-31-2008, 06:33 PM
primer84z's Avatar
also the tail pipes are a little long so your probably going to have to cut a little off them (1" or 2) to get the tips to sit right. If I put tips on them with out cutting the pipe it would stick out way too far.
Old 07-31-2008, 07:45 PM
Won't be a problem. I'l match the tips to where I want to see them in relation to the bumper and cut from there. Thanks for the advice though. Btw, what tips did you go with on your system?
Old 07-31-2008, 07:57 PM
primer84z's Avatar
I dont have any tips on there, Im going to put the stock ones back on there when I get some time.
Quick Reply: TSP Rumbler exhaust tip suggestions
