Do Loudmouth 1 And Straight Pipe Sound The Same???
Old 07-23-2008, 09:14 PM
nemss1's Avatar
Question Do Loudmouth 1 And Straight Pipe Sound The Same???
i was wondering if having just straight pipe (no muffler or resonator) would sound the same as loudmouth 1?
Old 07-23-2008, 09:43 PM
coocooknu's Avatar
I believe it would depend on what mid pipe you went with. Straight pipes are exactly that - straight pipes. But with the loudmouth you can have many mid pipes which create different sounds/tones that may or may not have cats (which would quite it down).
Look on www.ls1sounds.com for clips, I don't think they have any with straight pipes, but I bet it sounds like a dump truck lol.
Old 07-23-2008, 10:02 PM
nemss1's Avatar
Question
ok ill giv u an example: say u hav stock manifolds and y-pipe, and hav slp loudmouth 1 catback exhaust. wat if u removed the loudmouth 1 shotgun resonator and just weld in straight pipe. would that sound the same or similar to the loudmouth 1 since its just a hollow resonator?
Old 07-23-2008, 10:28 PM
Formula_LS1's Avatar
Yes, it would probably sound pretty similar in that situation.
Old 07-23-2008, 11:05 PM
ShortChevy's Avatar
At certian RPM's it might sound kind of similar.
Old 07-24-2008, 01:12 AM
nemss1's Avatar
i was wondering because i love the sound of LM1 but dont wanna spend the money and realized that LM1 resonator is just a larger section of hollow pipe. i was also wondering how just being a larger hollow section of pipe, how that would sound any different than just welding on 3 inch pipe wher the resonator would go mak it sound any different if it did sound different than pipe in its place?
Old 07-24-2008, 01:28 AM
180ls1's Avatar
if you want then just get a cutout installed and you can switch inbetween the two. They will have differences in tones, that is why it is called a resonator because it will chage the tone at certain rpms.
Old 07-24-2008, 10:18 PM
F-Body Lover's Avatar
I have a question : how about a true dual 2.5",X pipe and two resonators and turndown how it sound like? louder than the original LM1 cat back?
Old 07-24-2008, 10:20 PM
LS184's Avatar
^^ very loud....a member on here did it, he prob has some clips of it
Old 07-25-2008, 12:02 AM
nemss1's Avatar
ya im planning on getting another ss and going to put true-dual slp loudmouth on it going to be loud!
Old 07-25-2008, 12:50 AM
whats hes name or do you have a link to his thread?
Quick Reply: Do Loudmouth 1 And Straight Pipe Sound The Same???
