Cleaning out oily intake manifold
Ive just picked up an LS6 manifold and that came off another car that lunched its engine. Im going to fit new intake port and TB gaskets, smooth out the top with the dremel and then throw some colour on it
Whats the best way to clean it out "internally". Its full of oil (almost drips off my fingers) and who knows what else
Rags? Petrol?
Thanks
Rags? Petrol?
Thanks
i used a simple green/water solution with mine and cleaned it in the tub. i obviously let it dry for a real long time. i also sanded, primed, painted, and cleared it. turns out real nice, just take your time. you may want to pick up a catch can before you swap to keep the oil out of the new intake.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Simple Green will clean anything under your hood better than any other product. Carb Cleaner will just smear the oil around to different parts of the intake. Or you will use a buttload of it and just be a little bit cleaner than you were before.
Lol, Petrol. Where are you from?
I'd use Gunk engine degreaser, the kind that says use on a cool engine (as in not hot)
Spray it in there and let it soak, but you have to brush it. I'd find a good sized nylon brush and work it in real good, then hose it out with water.
When i was done sanding and smoothing the inlet of mine I used brake-clean, spayed it in all the runners and then thought the inlet and used a air gun to blow it all out, worked out real nice.
