Few more videos of my MS4/Borla XR-1 combo
Old 07-26-2008, 07:44 PM
98RedBird's Avatar
Default Few more videos of my MS4/Borla XR-1 combo
Man, the more I hear this exhaust the more I like it. It's QTP LT's into a QTP Y pipe into a Borla XR-1. They are short videos and I still need to get a WOT video but it gives you an idea. The car still has a hard time finding idle but it's getting closer. Also, I know I don't have the tips put on yet lol...
Idle Clip: http://s190.photobucket.com/albums/z...MVI_1450-1.flv
Small Rev: http://s190.photobucket.com/albums/z...t=MVI_1453.flv
Old 07-26-2008, 08:08 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Now you get the photobucket one to work! Excellent!
Old 07-26-2008, 08:10 PM
TORCHD 02 TA's Avatar
Did you recently get the MS4 installed? If so get a tune
Old 07-26-2008, 09:00 PM
98RedBird's Avatar
Yeah, I did. I built a motor over the winter and put the MS4 in it. I got a mail order tune from TSP because the nearest tuner is about 3 hours from me. I'm moving here in the next few weeks back up within a few hours of chicago so I'll have a place to get it on the dyno for a dyno tune then.
Old 07-26-2008, 09:23 PM
Engine_HP's Avatar
nice i think im getting one of those ms4. but will it work good on my ls1 stock heads and stock bottom ?
Old 07-26-2008, 09:26 PM
I would not start, or rev the car anymore w/o a tune. you could foul a plug or what not, your A:F is outta whack
Old 07-26-2008, 10:06 PM
98RedBird's Avatar
It does have a tune.... that's what I said. Then entire combo is from Texas Speed and I let them tune the PCM. I'm sure the tune is fine man. It's not going to hurt anything. They got it pretty close which is all I was expecting. Idle is just kinda funny right now, but it's slowly getting better. This is a very standard combo that they've tuned for time after time. I've checked the plugs numerous times during the first 80 miles and they look great. I'm not in the least worried about it.
Old 07-26-2008, 10:27 PM
Gary98Z's Avatar
Sounds sweet! Nice job!
Old 07-26-2008, 11:03 PM
AINT SKEERED's Avatar
You may be able to open your throttle body screw a little and then do a reset on throttle position.
try going out with the screw. IF it gets better then unplug your tp sensor turn the key on for 10 sec. Turn off key, plug sensor back in and turn key back on.
That may help it idle better.
SOunds good by the way
Old 07-27-2008, 12:39 AM
98RedBird's Avatar
Thanks man, I'll give that a try.
Old 07-27-2008, 05:22 PM
69_YENKO's Avatar
sounds good, lets us know how it does on the dyno and at the track
Old 07-27-2008, 05:33 PM
PI HAT's Avatar
I would definately look at your tune again. That motor sounds like its hurtin. I have alot of the same things you have and after a good tune, my car produced much faster times and alot more tq and hp. Not tying to bash ya but my unwanted 2 cents.
Old 07-27-2008, 06:10 PM
98RedBird's Avatar
Motor is fine... Thanks for your opinion.
Old 07-27-2008, 06:12 PM
98RedBird's Avatar
Will do man, I will be getting it on the dyno soon to get it fine tuned and the idle smoothed out. Car drives fantastic, just has problems when the load is taken off the motor. I'm sure it's something small like the IAC count is off or something.
Old 07-27-2008, 06:34 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Sounds mean.
Old 07-27-2008, 08:39 PM
twitchtwice's Avatar
according to his specs, he doesnt have an ms4, dont worry about what he says, he doesnt know what you have done to your car.
sounds great by the way.
Old 07-27-2008, 09:05 PM
blown03mustang's Avatar
dude that sounds good, once the idle issues are solved it should be a blast to drive! does it die out at redlights, or when ur coming to a stop?
by the way the borla really goes well with that cam
Old 07-27-2008, 11:18 PM
LebaneseShowoff's Avatar
That car sounds MEAN!!! Congrats and i would like to see Dyno Numbers when you get around to it.
Old 07-27-2008, 11:45 PM
98RedBird's Avatar
No, actually once it warms up it drives perfect. Idle's at about 975 and is steady. It's just when it cold and when it goes into park when I have problems. Also, if I goose the throttle it'll rev up and then usually die.
I'll be getting some up soon man!
