Which Y-Pipe for Jet Hot LTs
Old 07-30-2008, 09:02 PM
98form's Avatar
Default Which Y-Pipe for Jet Hot LTs
Long time lurker here. This site has so much info. I finally have a question that I could not find a clear answer to. I have the Jet Hot Long Tube headers, the ones based on the Hooker design. They are 1 3/4" and very nice. I bought the Jet Hot Y-pipe with it, the one that comes in a bunch of pieces and I bought the cat inserts to go with it. What a piece of crap. It leaks and just doesn't look like it flows well. It obviously doesn't do the job of reducing the emissions because my SES keeps coming on for O2 sensor bank1 sensor2 and bank2 sensor2. It also hangs down much lower than I thought it would and can scrape if I am not careful. I have the Hooker Cat-Back as well and I like it. Not too loud unless I get on it and no rasp. I installed all of this at the same time.
So...I need something else instead of the crappy Y. I was wondering if anyone knew of a catted Y that would fit my setup and is of good quality. If there isn't anything, I guess I will have to go with a custom Y. Can anyone recommend a good custom exhaust shop in the MD/DC/VA area?
Thanks,
98form
Old 07-30-2008, 10:40 PM
TUFAS4U's Avatar
tried TSP? they fit numerous applications
Old 07-31-2008, 11:51 AM
Fratsit's Avatar
I use the Mufflex ORY. Fits great. I have had zero ground clearance issues. My car is stock ride height. The pipe itself is a beast.
I highly recommend. I have pics if you want to see them.
Ooops..... I did not see that you want a catted Y. You can try the QTP catted Y. Same design as the Mufflex.
R/
Frat
Old 07-31-2008, 10:23 PM
98form's Avatar
Ok....I have been doing some more reading and it seems like most people have fit issues with the QTP. The Kooks Catted Y looks seems like a decent piece, and it is cheaper than the QTP.
Three questions:
1. Will both the QTP and the Kooks Catted Y definitely bolt up to my headers?
2. How much is the Flowmaster style collector worth, as far as power goes? How much better is this collector vs. a ypipe where the drivers side basically joins the passenger side? ex. Kooks
3. I have stock ride height, but I still want the best clearance. What is the clearance difference between the Kooks and the QTP?
Thanks for the help!
98form
Old 07-31-2008, 11:32 PM
fbodyman1026's Avatar
i would go with the tsp catted y and from what ive heard the qtp y pipe is
Old 08-01-2008, 09:23 AM
Fratsit's Avatar
I can't yet speak for the fitment issues with the QTP catted Y, but I have one sitting on my workbench and the quality apppears to be spot on.
Old 08-03-2008, 09:11 AM
98form's Avatar
I'm not reading anything very good about any of these Y-pipes. QTP, TSP or Kooks...it seems like for as many people that have success with them, there are as many or more that have fitment problems, clearance issues, or have to do some cutting or welding to make them fit. I want to be as emissions legal as possible, I need the o2 bungs behind the cats and don't want to have to pay someone to put those in. I just want something that bolts on without modification, doesn't leak, and doesn't hang low. It seems like that is too much to ask.
So....I'm guessing that I will have to go custom. Are there any decent exhaust shops in the DC/MD/VA area? Anyone have any experience with FBody Central in Baltimore?
Old 08-03-2008, 09:17 AM
LS1 Terror's Avatar
tsp or just have a custom one made like i did at your local muffler shop
Old 08-03-2008, 11:09 AM
Ohio Bird of Prey's Avatar
I am using the Jet Hot set up w/ORP. Fitment is OK for the most part.
I use exhaust wrap where each pipe is joined and then band clamps over that.
Seals very good and last quite a while.
Now what I don't like is where the pipes merge into the I pipe. Very poor design. Mine has been modified to open the hole up to increase the flow because you have a 3" pipe welded to a 2-2 1/2 hole. I will be cutting it up and welding in a new merge pipe.
Not sure on which I'm going with yet but will be doing this soon.
Old 08-03-2008, 12:57 PM
02silvaZ's Avatar
i have the jethot lt's and jethot ORY and everything went together pretty good, no leaks and no complaints
Old 08-03-2008, 01:37 PM
Kingc8r's Avatar
I believe JETHOT also uses Hooker headers with revisions made to them so I would think the Hooker Y would fit as well
Old 08-05-2008, 05:09 PM
98form's Avatar
Can anyone confirm that the Kooks Catted Y-Pipe will fit the Jet Hot headers?
Old 08-05-2008, 09:13 PM
Redlinez's Avatar
I took mine to an exhaust shop who added an extension piece on the passenger side to a Hooker ORY. Worked great for me.
Old 08-06-2008, 01:56 PM
Dal1as's Avatar
This guy is great. He did my custom y, custom subframes, etc.
Name is Tyson. Here.
http://www.performanceautofab.com/VS...=149&zoneid=19
