Secondary injection CODE!
Old 08-03-2008, 11:36 PM
philly3384's Avatar
Default Secondary injection CODE!
2001 trans am ...my cars check engine light came on and its the secondary air injection system where should i start and narrow it down... I can hear the air pump coming on and off as im driving is that normal?
Old 08-04-2008, 12:02 AM
LSX Mechanic
Damian's Avatar
It's an air pump code. There was a recall on certain years so you might wanna check that first. If you're in an area where you don't have to pass emissions, removing the air pump is fairly easy and cleans up the engine bay a LOT.
Old 08-04-2008, 03:52 PM
foreverzero's Avatar
I just cleared mine this morning. Its really nothing to worry about, just wait until you get your car tuned and have your tuner tune the codes out, and do the !AIR mod!
Old 08-04-2008, 04:27 PM
2001NBMZ28's Avatar
Post the code. Should only operate on cold starts - if you can hear it cycling after warm something else might be going on.
Old 08-05-2008, 03:15 PM
philly3384's Avatar
Default i just want to get the code off
i want the code to come off and not come back ... what could i start to change out .
Old 08-05-2008, 03:41 PM
2001NBMZ28's Avatar
We need the code to help you, there are several secondary air codes - P0410, P0412, P1415, P1416......could be something as simple as a clogged air check valve.
Old 08-05-2008, 04:34 PM
bigti99a's Avatar
yeah i have had check valves go on both sides. it may just be that, go get it scanned and post the code.
Old 08-05-2008, 11:00 PM
philly3384's Avatar
the code is p0410
Old 08-06-2008, 10:24 AM
2001NBMZ28's Avatar
This explains the operation/diagnostics: www.gearchatter.com/viewtopic9141.php
Old 01-03-2009, 03:15 AM
Player87's Avatar
hii have error codes P0412 and P0418.
can youplease tell me what i have to do to solve this problem. THX
