any tips on installing my exhaust.
Old 08-28-2003, 04:29 PM
jrp
SN95 Director
jrp's Avatar
Default any tips on installing my exhaust.
me and a buddy are installing my Jet Hot LT's, AAP Y, and Magnaflow catback. any tips on preparing for the install? thanks
Old 08-28-2003, 08:55 PM
Doc
Doc's Avatar
Default Re: any tips on installing my exhaust.
Relax, take a deep breath and turn on the FX, Channel or whatever cable rerun station, and watch a few episodes of McGyver for confidence. Don't panic at the first hurdle. The install should be fairly easy.
1)Metric Gear Wrenches your best LS1 friend
2)Plug wire pullers, second best friend- plugs
3) Oil drain plug
4) Filter
5) Breather above fliter
6) possibly stearing linkage- I did w/PPCs and it was just easier-maybe not necessary
Are you going to weld or clamp the Header to Y to CatBack? If clamp then get some Black 02 safe permatex rtv to ensure sufficient seal.
Might as well change them plugs and wires while your already there
Old 08-29-2003, 12:47 AM
jrp
SN95 Director
jrp's Avatar
3) Oil drain plug
4) Filter
thanks man
Old 08-29-2003, 03:48 AM
DaddySS's Avatar
If you're doing them without a lift, good jackstands and plenty of height is another freind.
Old 08-29-2003, 08:55 AM
LS1TECH Sponsor
Steve Burger's Avatar
I put the car up on cinder blocks and had plenty of room. Take your time and it is easy. I think you will need to pull the Oil Diverter right above the filter and the steering linkage. Other than that it is pretty easy just time consuming.
