changing cam on throttle bodies (help)
Old 08-16-2008, 12:48 PM
5301113's Avatar
Default changing cam on throttle bodies (help)
remove the whole TB from the car. Remove the TPS sensor. Remove the 2 screws going through the plate holding it to the shaft. Remove the plate. Tap the shaft out of the housing. The cam and shaft are all one piece. Use a little loctite on the shaft screws when reassembling.
__________________
I have a 98 ported tb and a stock 00 tb i have the instruction on how to remove the cam but the plate doesnt what to come off. How do i get the plate off .Am i missing something??
Old 08-16-2008, 01:02 PM
5301113's Avatar
got the plate but the shaft doesnt want to come out. Do i have hit the shaft really hard?
Old 08-16-2008, 01:17 PM
5301113's Avatar
I got it
Old 08-17-2008, 12:50 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Good to know.
Old 08-18-2008, 09:46 AM
5301113's Avatar
For anyone changing out the cam follow the instructions up top and on the plate, slide it out thought the top and hit the shift with a flat top hammer to remove the metal ring holding it in place, two good hits should be enough to get it out. I was surpised how much difference the cam makes. 00 and up have a bigger cam so the throttle response feels better.
Old 08-18-2008, 09:47 AM
formulajunky's Avatar
lol good info
Old 08-18-2008, 01:35 PM
5301113's Avatar
Originally Posted by formulajunky98
lol good info
Man I searched and searched and found some of the info but small details sometimes makes the biggest difference. So if someone is doing this and actually searches and find this page it will save the a lot of time and head scratching. I almost jacked up my cam trying to remove it so I'm passing the buck forward
Old 08-18-2008, 01:42 PM
bczee's Avatar
Pictures are alway great.. and speak for themself !
Old 08-18-2008, 02:08 PM
5301113's Avatar
Your right only if i would of taken pics at the time i was messing with them
