???CAR IDLES HIGHER AFTER REMOVING REAR o2's???
Old 08-19-2008, 10:25 PM
nemss1's Avatar
Question ???CAR IDLES HIGHER AFTER REMOVING REAR o2's???
after i removed my rear o2's, my car has been idling at 1000rpm's. what would be causing this?
Old 08-19-2008, 10:33 PM
nemss1's Avatar
here is a list of my mods but it didnt start idling higher until i removed my rear o2's and blocked the holes with bung plugs
MSD 8.5mm Superconductor spark plug wires
AIT sensor timing advance
K&N CIA
Hypertech Powerstat 160 degree
descreened MAF housing
ported & polished MAF housing
ported & polished TB
TB bump stop mod
TB coolant bypass
gutted cats
Flowmaster 80 Series
Shortbelt mod
3.73 gears
ASP underdrive pulleys
rear o2 delete
Old 08-20-2008, 12:39 AM
LSX Mechanic
Damian's Avatar
EDIT-
Have you driven the car around for a little bit?
Old 08-20-2008, 12:47 AM
nemss1's Avatar
ya, ive driven it around a couple of times. my car only started idling at a grand after i removed my rear o2's, so i wldnt think any of my other mods caused it. can rear o2's do this?
Old 08-20-2008, 12:50 AM
LSX Mechanic
Damian's Avatar
No they're not suppose to. It's possible something else could be causing it and it's a coincidence.
Best way to find out if thats whats causing it is to put the rear 02's back in, and see if it goes away. If it goes away, thats your problem and the PCM will require a tune to correct it. Usually however, removing the rear 02's only throws an SES code and thats it.
Old 08-20-2008, 08:47 AM
udienow's Avatar
what he said... i removed my rear o2's, and no change in idle.
Old 08-20-2008, 09:02 AM
JJD49's Avatar
Replace the 02s and see what happens
Old 08-20-2008, 10:03 AM
nemss1's Avatar
what is the stock idle supposed to be in park?
i have new front o2's, fuel filter, plugs and wires
Old 08-20-2008, 10:07 AM
nemss1's Avatar
would a lean or rich issue cause me to idle higher?
Old 08-20-2008, 10:27 AM
besch's Avatar
im having the same issue after putting headers in.
Old 08-20-2008, 10:30 AM
lemons12's Avatar
do you have LT's?? check all of your plugs/wires.. and clean your MAF
Old 08-20-2008, 11:19 AM
nemss1's Avatar
no, im still running the stock manifolds on an ORY. new plugs and wires. wires snug. should i mess wit the idle screw?
Old 08-20-2008, 11:28 AM
lemons12's Avatar
yea, you can... yuou wont have to turn it but maybe one turn... turn it, and then drive down the road, come back and check your idle..
it wouldnt hurt if that doesnt help to replace spark plugs... thats usually the problem...
i run rich and also idle high.. although my mods are different than yours.
Old 08-20-2008, 11:40 AM
nemss1's Avatar
could i have already fouled them if im running rich? they were replaced a month ago along with front o2's, fuel filter and wires
Old 08-20-2008, 11:55 AM
9000th01ss's Avatar
One suggestion. I've seen you posting basically the same **** all over the place here. Keep it to one or two posts for consistancy. It saves people time when they answer a question. If people here see you put up a mess of questions all over the place and are getting input from one person saying do this and another saying do something different, it kind of makes me at least hesitant to reply because it looks like a mess of information, and that alone is confusing you, making you try different things and adding more confusion. Pretty soon you're spiraling in a mess and ready to give up.
But thats just my opinion.
Old 08-20-2008, 12:15 PM
nemss1's Avatar
ok i understand, sorry. ya i could see where it would cause me confusion. the last thing id wanna do, is give up lol. gotta get the car running right again
Old 08-20-2008, 12:29 PM
5.slow99's Avatar
i believe the idle in park is like 600-650
Old 08-20-2008, 12:38 PM
9000th01ss's Avatar
Perfect example of what I just posted above.
Look at this thread about idle. https://ls1tech.com/forums/generation-iii-external-engine/973318-what-normal-idle-stock.html
I cut and posted these screen shots of factory programmed idle speeds for each varying condition. Thats how it's programmed, now you get a reply with an off the wall 'I think' guess.
I put some time in replying to that and now it feels like for nothing. So.....
Good luck, hopefully you can wrap it up in one big pile of info, sort through it and make something of it all.
Old 08-20-2008, 01:12 PM
nemss1's Avatar
Look at this thread about idle. https://ls1tech.com/forums/showthread.php?t=973318
well id definitly go off of the datasheet instead of an 'i think' answer
Old 08-20-2008, 01:26 PM
5_02ls1's Avatar
Default what haha ebay chip dumdumdum
K&N CIA
TB bump stop mod
TB coolant bypass
gutted cats
Shortbelt mod
3.73 gears
rear o2 delete
take that iat chip out and get a stock maf.....
check for loose vaccum lines if you have already look again...
