TSP 1 7/8 Long Tube Install
Old 08-27-2008, 12:59 PM
Camaro Junky's Avatar
Default TSP 1 7/8 Long Tube Install
Well guys I just finished up the install yesterday and I am very pleased with the TSP headers. I will be honest though, it was not easy. I had to remove both engine mounts on the driver side and jack up the motor.
Good news is if you can get 2 floor jacks and 4 jack stands you can get the car high enough to perform this task. Oh and I had some help, that is a must on this project because you can really get worn out.
Right now the SS running open headers and omg lol that ************ is loud, I went WOT and my ears started ringing. So the hell with dumping, I think I will get sick of the sound real quick.
So the only question I have is regarding the spark plug wires. On the passenger side there are 2 wires that are really close to the tubes, what should I use to protect the wires? I used the silver OEM tubes that were used on the manifolds, and there is still a part of the wire that is exposed. Thanks.
Old 08-27-2008, 01:03 PM
SOMbitch's Avatar
If it is just the boots use the MSD's that you can bend. What I did.
Old 08-27-2008, 01:05 PM
Yea I messed with the MSD wires where they connect to the coil packs and got them maybe a cm away from the tube, but I am afraid the heat will get them. Is that amount of spacing ok for the wires?
Old 08-28-2008, 04:14 PM
BlackLS199's Avatar
i JUST FINISHED MY INSTALL ALSO SAME PROBLEM YOUR HAVING I JUST TURNED THE ANGLE UP ON THE BOOT THATS ON THE COIL. I KEEP HEARING PEOPLE SAYING THEY HAD TO TAKE BOTH MOUNTS OUT. I GUESS I'M LUCKY AND ONLY HAD TO TAKE THE DRIVERS SIDE OUT!
Quick Reply: TSP 1 7/8 Long Tube Install
