Map sensor relocation question
I have a Fast intake that was on a corvette. The map sensor port has been drilled and tapped for a plug, but the egr plug has not been drilled like most for the map sensor. Where could they have relocated the map sensor to? I'm not sure if I can find a grommet the right size to install the map sensor into the now larger, factor port.
