people with true duals, please read
Old 09-04-2003, 04:23 PM
Turo's Avatar
Default people with true duals, please read
ok, i got my jet hot LT's in the mail, and i want to start planning out the rest of my exhaust. im going with true duals & hi flow cats, but what diameter should i use? 2.5" overall, 3" to the X then 2.5", or 3" overall? id appreciate it if you guys could please post what diameter you have and how you like it, thanks!
Old 09-04-2003, 04:47 PM
MOBE's Avatar
Default Re: people with true duals, please read
Do you plan on giong over the axle?
If not, I'd go with 3". Thats what I have, and my clearance is just as good (if not better) as the Hooker y-pipe was. btw... My car is lowered with the Eibach Pro-kit.
Does it scrape?... Sometimes. But never very bad, and only on tall speed bumps.
Old 09-05-2003, 02:56 AM
Mike K.'s Avatar
Yeah if you are getting dumps before the axle go with 3 if you are going all the way back over the axle get the 2.5
Old 09-05-2003, 11:49 AM
soundengineer's Avatar
just stick with 3" clearance is not an issue...and 3" sounds better than 2.5"
Old 09-05-2003, 12:33 PM
Jorday's Avatar
If you're going over the axle, used 3 inch up to the x crossover and 2.5 after. You can get a crossover than is 3 inch in and 2.5 out. With turndowns, I would simply use all 3 inch. That's What I did. I made my exhaust myself, and it has better ground clearance than my old mac y pipe. The new exhaust has never hit the ground. A word to the wise...It's gonna be loud if you just use bullet mufflers and turndowns before the axle, though the cats should reduce the noise some.
Jordan
Old 09-05-2003, 02:58 PM
XFACTOR's Avatar
Go with 3" and run it out the back.Sounds really good what I have and love it.
Old 09-05-2003, 04:17 PM
CySevans's Avatar
I'm running 3" to just before the axles, then have them flange-bolted to 2 1/2" tailpipes to go over the axles. I had them flanged so the tailpipes could come off for track use. I am eventually going to have the cats flanged and removable as well for the same purpose. No cats and just bullet mufflers was way too loud for everyday street use, so I added 3" cats. Still a little loud, but bearable. Sounds great!
