Help!!!!!!!!!!headers!!!
Old 09-08-2008, 01:05 PM
shaolink9's Avatar
Default Help!!!!!!!!!!headers!!!
i rounded off the last bolt on the drivers side changing myh headers i tried using a bolt extractor it did not work at all im at a stand still some 1 please help.
Old 09-08-2008, 01:25 PM
69lemansguy's Avatar
i know there no room in there, but maybe a small pair of vice grips? then put a small wrench on the end to get some leverage.also, if u have a small dremel toool, you can shave down 2 sides, and slip a small wrench on it. but there is a risk of that rounding as well... two different ideas i have used on other rounded bolts...
Old 09-08-2008, 01:26 PM
Deerhunter-Z28's Avatar
I would try vise grips, you should be able to get a small pair on the last bolt.
Old 09-08-2008, 01:33 PM
lastcall190's Avatar
Driver's side shouldn't be bad to get to. Try a small set of vice grips or some channel locks. Good luck.
-J
Old 09-08-2008, 07:26 PM
shaolink9's Avatar
one shop said the head had to come off
Old 09-08-2008, 07:48 PM
Can you get a pic of the predicament?
Old 09-08-2008, 08:00 PM
ryan00z28camaro's Avatar
vice grips would be my first try
Old 09-08-2008, 08:02 PM
Did it snap off flush with the head? Is ANY sticking out?
Old 09-08-2008, 10:32 PM
Formulated's Avatar
I think you mean that the hex on the bolt head rounded. If that is the case, look for a cam drive socket. I know snap on used to sell them, and they will definately get anything off.
If you broke the head off, then you should be able to get the exhaust out of the way and get on the shank of the bolt with vise grips. Sounds like a lot of work, but necessary.
Old 09-08-2008, 11:29 PM
badazz99ta's Avatar
just be gland u didn't strip the bolt hole. lol. if it is as u described I would throw up another vote for some vice grips. it should do the trick. good luck man.
Old 09-09-2008, 12:31 AM
shaun's Avatar
they sell those special sockets that are made for rounded off bolts i think craftsman makes em and you can get them to sears or k-mart.
Old 09-09-2008, 08:59 AM
NemesisLS1's Avatar
Changing the manifolds on my buddies ls1 a bolt rounded out and we used a dremel with the long attachment for it with a grinding stone to take the head down and we pulled the manifold over the bolt. Then used vice grips to get it out. But it wasnt the rear bolt... Good luck to you
Old 09-09-2008, 10:48 PM
SS1875's Avatar
Soak the hell out of it with some WD40 or something equivalent then as stated by all the others before me, put some vice grips on it.
Old 09-10-2008, 11:36 AM
shaolink9's Avatar
that wAS plan b
Old 09-10-2008, 12:15 PM
Unertl42's Avatar
I've always just welded a nut to it and continue where you left off.
