exhuast pipe vibration dampening
OK, so when my exhaust was put on apparently it wasnt the most professional install, the pipe touches the driverside floorpan and rattles like hell against it sometimes at low RPM.
I think I want to just pry the pipe down a little bit and try to slip some type of insulator between it and the floorpan, but i dont know if there is a specific material I should be using, seeing as how it gets hot down there. Is there something in particular i should use?
just dont want to set anything on fire...
I love having a dad that works for a nuclear powerplant...he got me this welding shield they use to cover up sensitive equipment when they make repairs. It looks like a blanket, but resists heat up to 2000 degrees, plus its silver. I just wrapped the pipe 6-7 times and secured with metal locking straps from DEI. Works awesome and I might use it for turbo wrap on my GN too.
