SLP Part # 23060, is it the 85mm MAF?
You just need the wiring adapter.
http://www.currentperformance.com/Ac...iring_acc.html
Get an inexpensvie GM MAF and this adapter and then you can use a MAF table from a Corvette to get you a base MAF tune.
The SLP maf is plug and play...This is straight from SLP's website:
Mass-Air-Flow Sensor, 1998-00 LS1 High-Flow
SLP's high-performance 85mm mass-air-flow sensor flows a whopping 895 CFM (90 more than the stock 75mm MAF)—enough to improve engine output by up to 10 horsepower. Or, remove the screen (not recommended on street cars) for an incredible 1000 CFM of air flow! This lightweight composite unit weighs one pound less than the factory MAF and is fully capable of supporting engine applications making over 600 horsepower. Compatible with stock and modified engines.
NOTE: For use with stock PCM tuning.
The SLP maf has a tune built into itself. It will automatically adjust your timing for a little more performance. All you do is plug it in, and in about 15 miles (your car will buck and stumble a bit, then smooth its self out), your car tunes its PCM to the MAF's settings.
I definately felt a differance with the maf installed.
